2022-07-21 10:44:42 Solution F103 F072 F030
With the popularity of the concept of intelligent transportation, electric vehicles have gradually become the first choice for short-distance transportation with their energy-saving, environment-friendly, economical and convenient features. According to the global consulting firm "Frost & Sullivan", China's electric vehicle market size is expected to grow from RMB 65.64 billion to RMB 108.99 billion from 2019 to 2023 at a compound annual growth rate of 7.22%, and the electric vehicle industry will become a blue ocean market with a scale of 100 billion.
An electric vehicle is composed of a motor drive, power supply system, and control system. It has the advantages of cost-effectiveness, low use cost, and fast speed.
Geehy APM32 series industrial-grade general-purpose MCU has the advantages of low power, high performance, high integration, and easy to transplant. It supports a 96-bit unique device ID (UID) with 8kV ESD, meets the industrial reliability standards, and has strong anti-interference and anti-static capabilities. The operating temperature of the full range of products is -40℃~+105℃, which meets the temperature requirements of a harsh operating environment, and can provide safe and reliable embedded application solutions for the electric vehicle industry.
APM32F103 Series MCU Electric Vehicle Motor Control Solution
· Efficient processing: Based on the latest Arm® Cortex®-M3 core with a maximum operating dominant frequency of 96MHz.
· Large storage space: Flash: 16-512KB, SRAM: 6-128KB, configured with enhanced external memory controller EMMC.
· Support-CAN communication module and comply with 2.0A and 2.0B (active) specifications.
· Support mainstream FOC algorithm library, with high conversion efficiency, effectively reducing controller temperature rise and extending battery life.
· The Hall sensor is used as the synchronous signal. FOC is used to realize the sine wave control mode to ensure the stable operation of the motor.
· Built-in FPU supports floating-point multiplication, which helps to improve the angle operation speed and accuracy of the Hall sensor.
· Support floating-point trigonometric function operation, which is conducive to arctangent operation and high-frequency injection without sensor and observer, and the generation of sine wave pulse injection signal.
· It has certified IEC61508 and USB-IF and meets the industrial high-reliability standard
APM32F072xB Series MCU Electric Vehicle BMS Solution
·Based on Arm® Cortex®-M0+ core with an operating dominant frequency of 48MHz
·Flash: 64-128KB, SRAM: 16KB
·Support sleep, stop and standby low-power modes and achieve longer mileage
·Support the simultaneous use of USB and CAN interface, and provide a
cost-effective USB scheme without an external crystal oscillator
·Adopt the technology of shutting after full charge, and support the charge, discharge, and power-off protection
·Support the use of voltage chargers with a wide range and support remote control
· It has certified USB-IF, which effectively guarantees no worry about the export of terminal products
APM32F030x8 Series MCU Electric Vehicle Display Screen Solution
·Flash: 32-64KB, SRAM: 4-8KB
· It supports up to 55 high-speed I/O ports, which can drive multiple LED light control and horn control
· Built-in SPI and DMA modules of up to 24MHz, which can ensure that the display screen does not get stuck and the content is refreshed in time
· It integrates SPI/UART/I2C communication interfaces, which makes it easy to plug-in NFC and Bluetooth. It supports Bluetooth wireless transmission and APP control
登录 之后才能发表评论
